Can someone solve this problem?
I'm trying to convert an AVI (Divx) to a MPEG2 (SVCD) file using CCE. For some reason it crashes every single time right after I select 'encode'.
Mostly I get the following error: set_file_pos(4212064185,1): An attempt was made to move the file pointer before the beginning of the file.(131)
I tried several versions of CCE (2.5, 2.62, lite, trial, SP) but it never works. I can play Divx-movies just fine.
My system is a Duron700@800, MSI-K7T Pro2, 320MB RAM. I'm trying to make a CBR MPEG2-file.
The problem is you're trying to convert a DiVX not a true AVI. You'll have to convert your file before using CCE.
Thanks for the reply Sully.
So first I would have to convert it to....what? Can I just load the DivX into VirtualDub and process it without compression? That would result in quite a large file I presume
I'm not the DiVX expert, but yes I would assume that would be the way to go.
One thing to keep in mind... No matter how you do it the quality will be less (maybe by a lot) than the quality of the DiVX. The DiVX is already encoded, so doing it even in another format again will result in quality loss. -
You can try frameserving the avi into CCE, with either Tsunami-Mpeg and VFAPI or just VirtualDub. Use older version of CCE, not 2.62.
May as well use the slower Tmpgenc freeware to encode divx to mpeg2 since it certainly supports it and CCE SP only converts from AVI/DV (how can they set the retail value of cinema craft at 3000+ US dollars?).
_________________
The last civilization will not be another civilization. It will be that long stretch of realization to which all other civilizations have pointed.- A. Miller
<font size=-1>[ This Message was edited by: tweakybird on 2001-07-20 20:05:22 ]</font> -
Darkbird: I tried that using 2.5, it didn't work. I received another error. I read somewhere on a forum that 2.5 might have issues with AMD-procs so I tried 2.6 also.
Tweakybird: Yes, Tmpgenc does it without complaining (I used it the first time). But I wanted to try another encoder because of a FF/RW and a time-display problem on my Philips DVD-player. I'm now giving LSX Encoder 3.5 a try.
See this thread: www.vcdhelp.com/phpBB/viewtopic.php?topic=50640&forum=1
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 24th Aug 2010, 00:17 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 21:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
