I have been using a Canopus ADVC100 for my hi-8 stuff for years....now my dad is getting in on the act as he won an ADVC100 off of ebay. He posed a good question to me and I am going to ask here.
Is it better to use the ADVC100 to stream the DV to your computer in 720x480 size (DV is 500 or so lines) or is it better to resize during MPEG2 encoding using CCE or Mainconcept. Anyone compare the 2 methods? It is faster NOT to have to resize of course. I love the ADVC 100 but have never tried these 2 methods....anyone?
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
I don't understand your question. You have no choice over what frame size the ADVC100 captures. You have to encode to MPEG2 if you want to make a DVD. You want to resize down to 352x480 or 352x240 for DVD? The former is OK if you need to fit more than 2 hours on a DVD. The latter is not advisable.
Why would you resize and what are you resizeing to? DV is interlaced and resizing could cause problems with the interlace if not done properly.
never mind....I looked at his email again. When I capture from my hi-8 camcorder I do not have 720x480, hence I capture via the ADVC100 to upsize on the go as I do not have that resolution. He asked if he needed to do that. Of course, since he is shooting DV, he does not as his DV is already 720x480 so there is no need for the ADVC100.
So it was just an email mess-up...thanks.
However, would there be a reason to go though the ADVC100 his case anyway...I guess be bought it for nothing LOL? I don't recall if it "cleans" anything like its replacement does.
thanks'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
He would not want to use the ADVC100. When he "captures" from his DV camcorder (assuming he's using a firewire cable) he is basically getting a bit-for-bit copy of what's on the tape. If he were to feed the camcorder's analog output to the ADVC100 and capture from that he would be degrading the image by the digital (tape) to analog (input to ADVC100) to digital (by the ADVC100) conversion.
yes that is right....but you can feed digitally from the DV camcorder into the ADVC 100 (not analog) and then via firewire from the ADVC100 to the computer. So this is all digital....I am just wondering now if the ADVC100 does any type of "video cleaning" or enhancement this way....
There is no enhancement. It would only be a firewire pass through port and serve no purpose that I know of.Originally Posted by ron spencer
Good software for capturing DV with Canopus ADVC 110?
By nikgelfi in forum Capturing and VCRReplies: 12Last Post: 28th Apr 2011, 09:39 -
Which Canopus DV capture box is best?
By Knightmessenger in forum Capturing and VCRReplies: 6Last Post: 26th Dec 2010, 18:59 -
Canopus ADVC300 - software?!
By Pixelrage in forum Capturing and VCRReplies: 21Last Post: 24th Dec 2010, 20:51 -
Capture Software Needed with the Canopus ADVC-110 ??
By christopheramos in forum Capturing and VCRReplies: 15Last Post: 23rd Feb 2009, 16:42 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 17:09
