I have several Ogm files with several audio tracks (English and Japanese). how do i recode them to ONLY have the english language in an avi format
Try dropping them into VirtualDub Mod. You may be able to see the different tracks in 'Streams' and delete the ones you don't want and save the video as direct stream and audio as full processing to a different format. Often, OGM uses Xvid for the video and Ogg for the audio. You can convert the Ogg to MP3 with VDM or with Audacity. If you want to use MP3 for audio, I would install the Lame MP3 codec. It will give you more options with VDM or Audacity.
I use all2avi for converting .ogm files with two languages to an .avi with just one language. Works also with .mkv files.
http://sourceforge.net/project/showfiles.php?group_id=156812
https://www.videohelp.com/tools?tool=alltoavi
You can download the latest beta version if you want but I haven't tested it myself. So the best choice would probably be alltoavi_3.0.0_R2_installer.exe. If you have any problems getting it to work just reply. Chose Divx or xvid codec as I don't think the wmv codec and mpeg2 codec work. Also, you can select which language you want in the right box.
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 01:56 -
OGM to AVI/DVD
By liveforit11 in forum Video ConversionReplies: 3Last Post: 20th Aug 2007, 22:20 -
Convert ogm to avi please?
By venus in forum Video ConversionReplies: 13Last Post: 11th Aug 2007, 18:15 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 15th May 2007, 00:33
