I am trying to burn a 700mb avi file to a DVD, to view on my DVD player. When I open the file in Nero, it tells me that the file is of too high a quality. Is there a way have the file fit the DVD, without sacrificing the quality? If so, what is the process?
Thanks,
JGM
over in the guides section to your left, and the Guide Forum (see main index) you will find many guides to encoding avi for DVD playback. You have not given much in the way of detail, however from what you have posted I will make the following assumptions (correct me if I am wrong).
1. The video is a DVD of a movie converted to Divx/Xvid format and downloaded from the internet (700mb is the give away here)
2. You are looking for a simple, no-thinking required process to convert. (Nero is the tell here)
If this is the case, I would suggest ConvertXtoDVD. It is much more reliable than Nero, especially where audio is concerned, and easily on par for quality.
Also, be prepared for the process to expose all the encoding flaws in your avi, even if you don't see them now (and if you don't, you aren't looking hard enough)Read my blog here.
What guns1inger said, and welcome to our forums.
You generally need to ask specific questions here to get specific answers. For general questions, we have our FAQ: https://www.videohelp.com/faq and our guides. <<<<<<
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
probelm converting .mov to .avi
By Derrydoc in forum Video ConversionReplies: 3Last Post: 28th May 2011, 18:10 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06 -
help burning AVI file onto DVD
By dunce in forum Authoring (DVD)Replies: 31Last Post: 10th Feb 2010, 20:40 -
Burning a AVI file to dvd
By tim_ver in forum Newbie / General discussionsReplies: 14Last Post: 7th Dec 2008, 08:05
