I have an EVGA Nvidia 7800GT and I used to have an ATI X800Pro both with VIVO and I would like to know what capture chipsets they use. How can I find out?
I believe that the ATI card uses the rage theater chipset. I have a x1900gt and that is the closest that i can get to an answer. As for evga, I have no idea
Go to device manager and open the 'sound, video and game controllers'. It should be listed there.
The name of the board would more likely be in 'Display Adapters' in Device Manager, but easier would be 'Control Panel>Display>Adapter'. But you may not see the chipset name or number.
A nice program that will tell you more than you probably ever want to know about your computer is the freeware SIW: http://www.gtopala.com/index.html Look under 'Display Adapters' when you run the program.
Picking a Capture Card chipset, going in circles..
By LukeS in forum Capturing and VCRReplies: 22Last Post: 21st Oct 2011, 07:21 -
SAA7130HL Chipset Off Brand Tv Tuner Card
By zeobo in forum Capturing and VCRReplies: 1Last Post: 2nd Nov 2009, 15:39 -
Philips SAA7134HL chipset Tv Tuner card !
By ganduman in forum Capturing and VCRReplies: 6Last Post: 5th Jan 2009, 02:43 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
