SVCD2DVD shows the project as being 2.94 GB but then it makes an ISO of 4.525 GB (according to Windows Explorer). so when Imgburn is called I get the error:
"Cannot add file to image!
ISO9660 Limit: 4,294,967,295 bytes.
Reason: File exceeds the limit imposed by the ISO9660 file system."
Any ideas?
Well, I looked a little deeper and found that for some reason some extra files left over from another project had been left in the folder. I deleted all the files in the SVCD2DVD_OUTPUT folder and then ran the project. All went well.
Hope this might help someone else sometime.
Yes, I have noticed that Imgburn will error out if there are any other files in the 'output' folder with a 'too large' error. If I need to save a VIDEO_TS folder, I rename and move it now.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
SVCD2DVD_TEMP.ISO shouldn't be created in the latest version of the program... Can you attach your log please?
SVCD2DVD and then burning with imgburn fails
By baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 13:57 -
SVCD2DVD and IMGburn
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 11th Apr 2010, 12:37 -
Help making ISO with ImgBurn
By stantheman1976 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 17:04 -
395MB folder to big to fit on 700MB CD in ImgBurn
By happydog500 in forum AudioReplies: 30Last Post: 30th Jul 2008, 12:58 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
