I understand that many professional units do not play any VHS or SVHS tapes other than SP. I have a Sanyo editing deck like that. However I am curious as to which ones *do* handle EP and LP tapes... especially in the JVC line but even beyond that as well (Panasonic, etc.). Any experiences one way or the other with specific models?
The reason the Pro models get better pictures and better tape interchange is because they are optimized to SP mode only. This allows the heads to be optimally designed for SP and S-VHS tape.Originally Posted by sphinx99
These were designed as production decks not as universal playback machines. You are more likely to find support for LP and EP on "pro" machines used in conference rooms or for screening S-VHS/VHS. -
Look for "prosumer" type decks or high end consumer machines rather than broadcast recorder/editors. They usually have LP and EP playback capability.
I understand that. Should I interpret these replies to mean that the JVC and Panasonic broadcast decks (none of them) play EP or LP tapes?
I'm trying to get some specific answers here, after being told by someone who used to work at a studio that some of their broadcast SVHS decks DID play EP tapes because sometimes they used them as sources for EP tapes that they were receiving from, say, someone's home movie, that they wanted to edit scenes out of to broadcast as part of a story. So, I'm trying to get a feel for which models are confirmed to play (or not play) non-SP tapes... by model number if possible. -
That's correct. The large, heavy duty broadcast machines generally are single speed (SP) only.Originally Posted by sphinx99
Some (I said SOME) of the pro-machines can play EP tapes in jog/shuttle mode when you use your jog dial and set the correct speed. Some machines can recognize the correct speed of playback. AFAIK this trick is available on some Panasonic pro-machines
JVC HR-DVS Decks
By braxus in forum RestorationReplies: 1Last Post: 8th Nov 2011, 14:28 -
Sony SVO-5800 (or other SVHS decks) with Component Out
By quicksilverg4 in forum Capturing and VCRReplies: 25Last Post: 13th Nov 2010, 08:52 -
Interesting update for D-VHS decks on JVC site? & HM-DH4000U on sale at B&H
By OldMedia in forum RestorationReplies: 3Last Post: 4th Jun 2010, 23:20 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 16:23 -
Any SVHS Recommendations?
By adondeeres in forum RestorationReplies: 34Last Post: 6th Mar 2008, 02:50
