I have ProjectX and it states:
[FILE] @ C:\06.08.30.I.Robot.机械公敌.hdtv.H264.DTS 双声.1080i.OAR.9.3G.orbitlee@www.silu.info
Name:
I Robot.1080i.OAR.H264.DTS.orbitlee@silu.disk3.ts
Size:
756 MB (793,459,828 bytes)
Date:
January 23, 2007 7:25:14 PM EST
Type:
TS (generic PES Container) (SID 0x2 ,PMT 0x20)
Video:
PID: 0x21(H.264)
Audio:
PID: 0x24(DTS2)[PD]
PID: 0x26(AC-3)[PD]
Teletext:
n/a
Subpict.:
n/a
est. Playtime:
Note that it states H264 in it.
I can play the file on mediaplayer classic and it looks great, but the video stops/sputters/ slows down/speeds up and is generally out of time with the audio.
I would like to play this from a notebook as I have done in the past with other TS files that I converted to Mpeg, but this one will not convert the same way.
I can strip the DTS and AC3 files, but video is dropped and never produced as a 3rd file.
This has been a problem for a couple days now, I cant seem to use this movie.
I'm stumped and about to just toss the whole fileset.
How fast is your notebook? Using CoreAVC as decoder and Media Player Classic you might get smoother playback....if you haven't tried that already.
How to convert to hd avi (divx/xvid)
https://www.videohelp.com/forum/archive/t305752.html
http://dvbportal.dyn1.de/forum/index.php?topic=732.msg4058
...not to mpeg2 but divx/xvid might be enough... -
no no no, the notebook isn't part of the equasion, YET, sorry for the confustion.
I am attempting to play it on my 3.6 ghz hyperthreaded system with ATI Radeon9800 series video and 2 gigs of ram.
I have the Cole2k Media - Codec Pack installed.
You still suggest the links you listed and the codec pack? -
Okay, now ive gone from the frying pan, into the fire...
Now mediaplayer classic wont play it at all.
Argh...
The quality is amazing when it does play the bits that it does.
However, i'm rapidly losing interest.
I just read a post that outlined how to use a HEX editor to change somf bytes in the files after various convertaions and demuxing processes.
For gods sake, I really dont think this should be this hard!
argh!
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
DTS OR AC3 to mpeg1/2 4 divx or h264
By DRINGO in forum AudioReplies: 1Last Post: 31st Dec 2011, 12:16 -
h264 dts to MP4
By kerb in forum Video ConversionReplies: 1Last Post: 18th Nov 2011, 11:52 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
MKV H264 bitrate reduction (also DTS to AC3)
By Tooncis in forum Video ConversionReplies: 0Last Post: 2nd Jun 2008, 09:33
