hey guys, ive recorded something on my cell phone and transfered it on my comp.
unfortunetly i recorded it with the angle facing the wrong way.......
does anyone know a software that can rotate my video angle into the right way
thank you!
cheers
The simplest way I know to rotate a video is with Virtual Dub. Load your clip, then click Video --> Filters then "Add". If by rotate you mean turn your video on it's side, scroll down to Rotate, double click it, and select your rotation. If you meant flipping the video left to right or top to bottom, there are filters for that also. You can resize, enhance, crop, etc. as well. You may also want to select the compression (also under the video tab) as well, since the new avi you save could be quite a bit larger than the one you started with if you don't.
This is assuming that your clip is an avi. If it's not (say it's in wmv, mov, asf, flv, etc) you'll need to convert to avi first (perhaps with SUPER... there are many "such and such to avi" converters), then use Virtual Dub.
There are probably several other ways to do this (Avisynth springs to mind, but you still need a seperate encoder) but I think this is the most straitforward one. If there's any more to the process that your interrested in, feel free to ask.
Rotate 3GP Videos at 270 degree Angle
By ParryD in forum Portable VideoReplies: 13Last Post: 9th Feb 2015, 01:37 -
How to ROTATE a video (quicktime or anything)
By nerys in forum EditingReplies: 2Last Post: 21st May 2011, 07:45 -
How can I rotate mpeg video?
By spurs61 in forum EditingReplies: 10Last Post: 23rd Mar 2010, 18:13 -
rotate video 90 degrees?
By cduval04 in forum EditingReplies: 6Last Post: 8th May 2008, 13:53
