I want to rip all of my dvd's (main movie only) into PC video files so I can just click and access them when i'm on the road rather than carry a bunch of dvd's with me
I enjoy upconverted DVD quality and I want to know if I can encode DVD's directly from the movie and upconvert it using software to a 720i or 720p level?
If so where should I start reading to accomplish this
Results 1 to 12 of 12
What are you going to be accessing/viewing them with? A laptop?
You realize that you will be creating some rather large files on your Hard drive. -
yea that would be fine , the file size isn't a problem i ahve an external i have to carry with me for work any way so yes it would be for a notebook but in the future i'm looking to stream it around my house
You could rip the dvd's to an mpeg file maintaining 1:1 quality. Although the files would probably range from 3-7GB depending on the movie..
For highest quality, don't encode (or re-encode) anything, just rip the DVDs in file mode (main movie only) & play with software DVD player.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
thank you for the advice but what would I have to do to output the movie at 720p ? In the end my goal is to throw this onto a media server and watch it around my house on a HDTV without using the discs
DVD is 480p, you want 720p. If you re-encode to 720p, the extra lines of resolution are only interpolated. It's like asking how to make a DVD look as good as an HD-DVD. I don't believe you'll find an acceptable software solution. Perhaps you could look for hardware (maybe a some type of video card) with an upconverting feature similar to the ones offered in some DVD players.
George Carlin -
In other words, there is no 720p in a 480p DVD. It has already been compressed.
http://www.kiva.org/about -
so I guess this wouldn't be as easy as just changing the resolution of the output file?
Explain your reasoning.Originally Posted by too2buff
Usually the video display card, dvd player or progressive TV handles resolution scaling.
Also people usually want smaller file sizes that fit DVD media. -
No, because you won't realize any video quality gains. You can't turn 2 into 5.Originally Posted by too2buffIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Your player software or your TV will do the up-conversion on the fly. You don't need to store anything that isn't on the original DVD.
What's the highest quality AVI to digitize video to for future editing?
By jbandy1 in forum EditingReplies: 21Last Post: 22nd Aug 2011, 12:11 -
Is this the highest possible quality for YouTube? YouTube compresses video?
By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 12:33 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 16:57 -
How to get highest quality video? miniDV to hard drive.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2008, 01:54 -
Compressing with the highest quality
By guitarscn in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2008, 15:02
