I burned a SVCD using nero and it plays fine in WinDVD but nothing else. I compared file sizes and AVSEQ01.mpg is slightly smaller than the original mpg was. Is there a program I can use to fix this and make it playable in wmp like it was before burning it to a cd?
do you mean you wan to convert the dat file back in to a mpg file...iso use VCDGear
do you mean you wan to convert the dat file back in to a mpg file...if use VCDGear
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 11:50 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
Question how to convert mp3 to standard cd that cd player can play
By jimdagys in forum AudioReplies: 5Last Post: 21st Oct 2008, 22:49 -
BEST way to convert HD video to standard DVD?
By senorroboto2k5 in forum Authoring (DVD)Replies: 43Last Post: 14th Sep 2008, 02:35
