    Dec 2006
    Bangladesh
    I make an slide show vb program with transition effect. But i want to make mpg file from thoose bitmap. Plz help me with source code.
  2. VB alone is a bad choice to write a program for mpeg encoding. The best practical way would be to save thoose bitmaps to an avi file (thats easy, here is an example: http://www.shrinkwrapvb.com/avihelp/avihelp.htm ). Then use a commandline mpeg encoder (HC, QuEnc...) for the conversion to mpeg.
