Every time I convert a movie that has an anamorphic aspect ratio it always comes out 4:3
Can someone help please?
Assuming you're converting to DVD, you may need to letterbox to retain the original aspect ratio.
Please provide details of your conversion preset and source aspect ratio.
I have a similar question.
I am trying to convert a Full Screen 1.33:1 from Video_TS to .H264. Since Mencoder is the only option for that conversion I cannot Letterbox. Does anyone have any suggestions to keeping the correct aspect ratio?
Thanks!
Originally Posted by ctwelsh
If 640x480 is too large for your target format, then pick a lower width/height combination where each number is divisible by 16 and close to 1.33:1 for width:height.
(E.g. 624x464, 592x448, 576x432, 560x416, 528x400, 512x384, 496x368, 464x352, 448x336, 432x320, 400x304, 384x288, 368x272, 336x256, 320x240... Note that the height is -16 for each number in this example row, and the width is matched to the height using the aspect ratio.)
i have the same problem as mudger, at least i think so.
it just doesn't matter what format i encode into, but to give an example, i want to encode a avi mpeg4 720x416 into ffmpeg mpeg4, so that itunes is able to play it. ffmpegx default preferences in the video tab are now ratio: 1.85:1 at 720x400
should work fine except for little corrections to be made. the thing is, that if i play the output video with itunes, it is played with the correct aspect ratio 1.85:1, but mplayer, vlc and other players use 4:3 as a default. i could tell mplayer manually to switch to 16:9, and then it is displaed properly, but thats not the idea behind it, is it?
i use ffmpegx 0.0.9x
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
maybe i should get a newer version? where and how can i do so?
tanks a lot for your help!
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
DVD to AVI to DVD keeping aspect ratio
By sambat in forum Video ConversionReplies: 5Last Post: 3rd Feb 2010, 10:45 -
Extract part of picture while keeping right aspect ratio
By cd090580 in forum Video ConversionReplies: 12Last Post: 6th Oct 2008, 06:04 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 07:21 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 12:55
