I was reading a how to clean heads from VCR according to a technician with years in the field and seem very confident... he recommended to use this fluid to clean the rubber pinch roller on the VCR that will both clean and recondition the thing. However I got all that he asked... except this... which can no be found. Before you ask me if I try ebay or reselleratings or around google I say you should see that I empty all posibilities.
Anyway the site is...:
http://www.bealecorner.com/trv900/trouble/headclean.html
-some people say on this page (DAT "talk"):
http://www.tape.com/techinfo/datclean.html
that the pinch roller can be clean with alcohol and not matter if it dries out and die it has to be changed every 1-2 year anyway or every 1500 hours, other say don't use alcohol instead use mild soap water for it...
-On here it says is safe to use alcohol Isopropyl (I can't believe it)
http://www.videointerchange.com/tips.htm
What is your say?
The advice on the above link seems good to me.Originally Posted by CCEncoder
Isopropyl alcohol is perfectly okay - as long as you heed the advice given in the link above and by everyone who has already replied on this forum.
Non-slip fluid
My guess (I'm a chemist when not a video geek) is that this refers to xylene, a solvent commonly used in the preparation of non-slip surfaces. e.g., http://www.protectakote.co.uk/faq.htm
One of the links you provided mentions that you can use xylene (tradename Xylol) to clean the capstan. The capstan is metal and it is okay to use xylene. But you must avoid getting xylene on any of the plastic/rubber parts.
Also, PLEASE be careful when using any of these solvents. Treat them with respect. Xylene is toxic - http://www.ccohs.ca/oshanswers/chemicals/chem_profiles/xylene/working_xyl.htmlJohn Miller -
Re: NON-SLIP FLUID, I have an old bottle of Radio Shack's NON-SLIP FLUID 2Fl. Oz. Cat. No. 44-1013. The contents are as follows: Isopropyl Alcohol, Trichloroethane, Diethylene Dioxide. Hope this helps.Originally Posted by JohnnyMalariaI have an old 2 Fl. Oz bottle of Radio Shacks NON-SLIP FLUID. The contents are Isopropyl Alcohol #67-63-0; 1,1,1 Trichloroethane #71-55-6;1,4 Diethylene Dioxide #123-91-1 I hope this helps someone.
Bogen Manfrotto 3063 Fluid Head Wobble
By birdbrainz in forum Newbie / General discussionsReplies: 4Last Post: 29th May 2010, 15:43 -
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 23:12 -
Image Burn SLIP
By wulf109 in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jan 2010, 16:18 -
ORBYX: Fluid DVD boombox 1607001?
By snako in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Jan 2010, 22:29 -
Create your own cardboard or plastic DVD slip cases?
By lordsmurf in forum MediaReplies: 3Last Post: 23rd Jun 2007, 18:31
