I noticed that the svcd(NTSC film) files created by vers. 2.02 are alot smaller than 2.01 and earlier. Is there an explanation for this?
ae you sure it was the same length as the movie you encoded with 2.01 and movies are diffrenet they can be compressed diffrenetly
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
