  1. Hi
    I am trying to code back some avi (divX) files to MPG with TMPGEnc. After I did my settings and hit the start button the programm closes itself. Anybody has an idea what the problem could be?
  2. Try reading the help files on this site , you will see that you cannot just convert (divX) files to MPG with TMPGEnc you first have to convert the divx back to a standard uncompressed avi.
    The quickest prog for this is virtualdub ,on my pc it takes just over an hour.
    Then you can use TMPGEnc to convert to mpg and make into a vcd which takes about another hour.
    Hope this helps but all the info is allready here for you.
