Hi i have mkv toolnix and mkv merge both work great![]()
I input my .mkv file (which had a selectable english subs) and demux it into 3 separate file the video, audio and subs(which is a .ASS text file)
I then remove the original file i demuxed and load all 3 separate file back into mkv toolnix/merge, and start the muxing process to merge them, file comes out great but the subs are still only selectable from the video players menu, not hardcoded onto the video file itself, my first question is what am i doing wrong?, does mkv merge hardcode subs?
And second if it does how? and if it dosent how do i go about it any help will be SOOOOO welcome , Triple thanx in advance![]()
I tend to steer clear of mkv files, however looking at the toolkit you are using, it appears to be basically a muxing engine to combine all the streams into an mkv container. In order to get hardsubs you would have to re-encode the video with the subs, which this tool does not appear to do. Look for posts involving vobsub and virtualdub for instructions on how to get your subs encoded into the video itself, then use this video for your new mkv file.
Read my blog here.
Hi, thanx 4 your help
Yeah i really hate mkv file formats, such a pain in the butt to convert especailly with lots of subs etc. but some cool shows i like are mkv files and i have to deal with it hahahah sucks though, i will check out the programs u suggested
Hardcoding subs problem
By jliggett in forum SubtitleReplies: 3Last Post: 3rd Feb 2011, 18:04 -
hardcoding subs
By zammil in forum SubtitleReplies: 27Last Post: 24th Sep 2010, 04:10 -
help hardcoding subs to mkv
By striker9 in forum SubtitleReplies: 14Last Post: 20th Aug 2010, 06:40 -
Help hardcoding subs to mkv
By striker9 in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2010, 02:01 -
Hardcoding subs problem?
By elliottpen in forum ffmpegX general discussionReplies: 9Last Post: 22nd Apr 2010, 18:24
