Hi I bought a dvd Interactive game which I downloaded from the net as a .img file I burnt as a image file in nero but when I play it on my home dvd player it gets to where u select single palyer etc then dvd just stops. it seems to play on pc, also I used a duel layer dvd as game is 7.91gb which way should I have burnt this to make it play on my dvd player
Results 1 to 12 of 12
Does your player at all support dual layer recordable disks?
What brand did you use? Verbatim is reported as the only reliable dual layer disks around.
ImgBurn is a better option for burning DVD images to disk.
/Mats -
well here is my dvd player its a bit old so maybe thats reason why
http://www.dvd.reviewer.co.uk/reviews/hardware.asp?Index=9581
and the duel layer dvd`s I used are RiDisc
www.ridisc.com
do you think its worth trying imgburn to try out another. trouble is these duel layer discs are not cheap -
No idea, actually. DL disks are expensive, yes. If I was you, I'd bite the bullet, and try to shrink this DVD down to DVD-5 size if possible. I managed to do so with my "Who wants to be a millionaire?" disk.
/Mats -
what do i use to shrink down to dvd-5 size this must be 4.31gb yeah on a single layer dvd-r I have dvd shrink but i dont think it will shrink this 7.91gb to a single dvd at 4.31gb or is there anything what will
when i tried to do it just now dvd shrink gave me an error saying out of memory not enough storage is available -
I used DVDShrink. That error message seems like some hardware trouble, like low on HDD/RAM?
/Mats -
I have 768mb of ram and my 3 hard drives free space left is 44gb 30gb and 74gb space free so i cannot see whats wrong I have mounted the img file and in dvdshrink I go to open disc which is the mounted image it starts to analyse but dont get to 2% then pops up with that error is there anymore good programs like dvdshrink
Try ripit4me - may be some kind of copy protection, even if that seems odd for a disk delivered as an img file...
/Mats -
I am also giving dvd decrypter a go so what would you reccomend to burn this when done
DVDDecrypter just creates a 1:1 copy, so wont do you much good, but for burning, DVDDecrypter is fine too, only bettered by imgburn (by the same author as DVDDecrypter, but still developed/maintained)
/Mats -
posting this here as posted in wrong place sorry
wish I knew but I cannot play this dvd interactive on my home dvd player it gets so far and finishes its a duel layer dvd I believe I did say to you about this the other day
looking 4 FX creator 4 dvd/br interactive menus
By cesarin in forum Authoring (DVD)Replies: 0Last Post: 30th Dec 2011, 08:55 -
Interactive DVD Authoring Advice please
By Arron in forum Authoring (DVD)Replies: 1Last Post: 26th Apr 2010, 07:48 -
Interactive DVD menu
By aloram in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2010, 01:10 -
Creating a DVD with Interactive Menu
By magus2008 in forum Authoring (DVD)Replies: 11Last Post: 20th Nov 2008, 06:33 -
Interactive DVD`S
By natty in forum Newbie / General discussionsReplies: 18Last Post: 5th Feb 2008, 02:58
