    Oct 2006
    India
    hi i need an application that allows me to author a DVD where i can use both numberical keys as well as the navigation keys instead of just using the navigation keys.
    Apr 2004
    Miskatonic U
    Perhaps you need to explain a little more fully what you are trying to do. Mostly the buttons on the remote are the same from tool to tool unless you program them specifically to do something different.
    On the PC you would be looking at DVD Lab Pro, Maestro or Scenarist to get to that level of programming.
    Read my blog here.
    Sep 2004
    If you mean pressing the number keys on a remote to activate a button then encore can do that. it gives you total control of the button numbering.
    Ken
    Apr 2004
    Miskatonic U
    Buttons on the remote, by default, refer to button order on the menu. Therefore any authoring tool will offer what Encore is doing, simply by authoring the buttons in the correct order. Although I'm sure Encore makes it look like it is a special feature.
    Read my blog here.
