dfb
HDV is not really a web format at all .... did you shoot the raw material in HDV ? or DV ?
in fact DV is not a web format either (both HDV and DV are going to be very large files) ..... and there is no such thing as uncompressed DV avi ....
for web use - you should export in most likely windows media format (though there are other good choices like on2 flic and others)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
