  1. ok, i capture some video off tv with my ati aiw radeon card and i want to join my mpg files together. i can't find an easy way! what is the best program. i've tried camel's mpegjoin and that didn't work. and dos command copy /b causes it to pause a bit. there has got to be an easy way. please help!
  2. I use the merge&cut utility (under FILE->MPEG TOOL) in TMPGEnc. It works fine for me but sometimes it just skips a few frames as intended. After I reran, it's OK. I like the EDIT part, you can use the arrow key to control which frame to start or stop.
