Will anyone recommend a good HDTV over the air tuner? I made the mistake of buying a HDTV that does not have a built-in tuner. Your help is appreciated.
	http://www.jr.com/JRProductPage.process?Product=4144839
 or onecall.com , or amazon.com
 " on-screen display does not work over Composite or S-Video " you need an HDMI
 if you live far away from the tower start looking also for a big nice Antenna
	Thanks for the help. Since my HDTV has a DVI input, will it work if I buy an adapter to go from HDMI on the Samsung tuner to my DVI input on my HDTV?
	there is tons of info about the tuner here .
 http://www.avsforum.com/avs-vb/showthread.php?t=728392&page=4&pp=30
 if you want to buy DVI to HDMI monoprice.com is the right place
 http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10231&cs_id=1023104&p_id=...seq=1&format=2
	Thanks for all the post. I've decided to go with that. I'll try to pick it up at a local Best Buy store since the price is similar from online.
  hdtv tuner for over the air channelsBy carlos28355 in forum DVB / IPTVReplies: 7Last Post: 21st Jun 2010, 19:07
  HDTV TunerBy olyteddy in forum Capturing and VCRReplies: 0Last Post: 25th May 2009, 18:59
  Wanting to record/playback over the air hdtv...please helpBy jnaarnold in forum DVB / IPTVReplies: 6Last Post: 16th Jan 2009, 22:57
  Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43
  Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
