This has been an ongoing problem for me. I've completed my sequence in Final Cut Pro 5. I export it using the .DV option. My goal is to encode the .DV file into XVID using ffmpegx. But every time I try, I get an annoying "encrypted VOB file." Hello, its a DV file!
Geez, all I want is a stand alone app that can take a .dv file and convert it into an xvid. I've tried d-volution but that thing doesn't work nor has it been updated.
Otherwise, can anyone PLEASE recommend a work flow to go from Final Cut Pro to an XVID.avi that can be played on mac AND pc? I KNOW it can be done.
Thanks.
If your not set on using DV then go for .MOV or .AVI but use the DV/DVCPRO codec when exporting from FC. Then drag that into FFMPEG to any format.
Hauppauge PVR footage won't import into FCP
By blacklevel in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 10:25 -
i cannot encode with ffmpegx
By Se0r in forum ffmpegX general discussionReplies: 8Last Post: 24th Sep 2009, 12:38 -
ffmpegx won't encode at all--Ram to Mp3
By redwillow in forum ffmpegX general discussionReplies: 1Last Post: 6th Aug 2009, 09:55 -
FFMPEGX won't encode!
By Kalasin in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2009, 11:02 -
FFmpegX can't encode vobs
By sgee34 in forum ffmpegX general discussionReplies: 3Last Post: 15th Jun 2008, 17:07
