Hey All,
I am currently using Vegas 7 to make a home movie, finding my way round it is pretty straight forward, ie setting up a intro to movie with still pics extra, extra.
Now comes to adding my video content from DV Cam. I have set up using SV Capture 6 all works fine, just that the problem is.... it seems to split up the captured film into 3 files/chunks rather than one piece, now the DV piece i am using is my daughter talking, when you add these to the timeline each piece does not match with audio continuity. This speech is only 1.5 mins long.
I have found in the help section of SV Capture 6 this:
Video Capture will create multiple files if it detects scene changes or when the operating system file size limit is reached (4 GB under FAT32 disks).
(I Have no scene changes/and file is under 4GB).
I have used pinnacle and ulead before and the captured file is whatever length/size you want rather than splitting it up in to various sized chunks as with Vegas Capture 6 is there something I have over looked in the set-up of SV Capture 6???
cheers in advance
....:: Pipe.....::
PS. is the easy way out D/Ling WinDV for capture?
thanks for the input edDV, had been messing with the preferences, to see what worked best.
Just found under disk management tab - it has max size per dv clip selected at 640mb I unticked and my piece came out as 1 file! Nice...
BTW the 1 piece file was only 382mb, so why the smaller files, they where not even equal sizes/lenghts....?? ummmm
Cheers
Pipe.....::
Capturing (Sony Vegas vs Window Movie Maker)
By Clear_Mist in forum Capturing and VCRReplies: 10Last Post: 3rd Oct 2011, 21:15 -
Trouble Capturing to Sony Vegas 8
By croonprince in forum Capturing and VCRReplies: 6Last Post: 26th Jul 2011, 23:38 -
Best settings in Sony Vegas for capturing DV video
By fuzzblaster in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2010, 00:39 -
Capturing video through Vegas Movie Studio 9
By Michael Rodriguez in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2010, 17:33 -
Capturing a still image from video in Sony Vegas 8.0 Pro
By ruffryd in forum EditingReplies: 2Last Post: 29th Oct 2008, 17:49
....:: Pipe.....::
