Hey, can anybody tell me what the best program to convert WAV to DVD-Compliant AC3 audio is? Also, is there a guide or tutorial for it? Thanks!
Originally Posted by Baldrick
Edit: Whoops, I just noticed I posted this in the video section. Let me know if I should repost in the audio section. Sorry about that. -
Originally Posted by hiimbored
General: Just set the bitrate that you want to use.
Level: Leave everything alone
Filters & Overrides: Check Bandwidth Low-Pass Filter and High-Pass Filter. Change Audio Coding Mode to match the WAV file that you are using.
Misc: Leave everything alone. -
Originally Posted by LloydAZ
This app is good and easy to use to resample audio. Best of all, it is free
Set it for 48000 and 16bit
http://www.voxengo.com/product/r8brain/
Then again, Audacity must have this ability to resample as well.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 02:29 -
Convert 2.05gb wav to AC3
By colt4523 in forum AudioReplies: 7Last Post: 15th Nov 2007, 06:28 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 15:48
