Hi All,
Is there a utility that will tell me what my currently colorspace is in a video? I want to know if my video is RGB24, RBG32 etc.. I want it to be more detail. I'm not really a fan of Gspot, since I found out that its been reporting false field order.
Thanks!
Matt
Sony Vegas 7.0d
Virutual Dub
Avisynth
Out of curiosity, do you mean the colorspace used for the encoding or the colorspace being used during playback/rendering.
e.g., DV's native colorspace is YUV 4:1:1 (NTSC) or 4:2:0 (PAL) but DV decoders will offer up RGB24, RGB32, UYVY etc etc.
(Our DV decoder has an option to display the current decoded colorspace on the video, for example).John Miller -
I'm using NTSC.Originally Posted by JohnnyMalaria
Yes, I mean both colorspace used for encoding, and the colorspace being used for playback.
The reason why I'm asking is because I'm trying to use NeatVideo/VirtualDub to cleanup a DV uncompress file. Then import the file into Sony Vegas to add lower thirds then export out to Mainconcept/CCE Basic for DVD. When I tried this, I noticed my video quality was terrible. So, I'm thinking it has to do with the number of times the colorspace has changed.
When I skipped the SonyVegas edit, it looked great, but I need to add the lower thirds. So I figured if I could keep up with the colorspace change, hopefully I won't loose as much quality.
Matt -
You can give our Enosoft Enhanced DV Decoder a whirl to try to see what colorspaces are being used.
If you look at the How-To on burning timecode, you'll see screenshots that show the colorspace info.
(You will need Windows 2000 SP4 or later and a CPU with SSE2).John Miller
what colorspace to select in Lagarith ?
By codemaster in forum EditingReplies: 1Last Post: 1st Jan 2012, 10:44 -
colorspace conversation elaboration
By mammo1789 in forum RestorationReplies: 13Last Post: 18th Nov 2011, 14:36 -
Converting YUV Colorspace
By mlong30 in forum Video ConversionReplies: 4Last Post: 13th Dec 2010, 09:00 -
Avisynth colorspace conversion - How to do it right?
By MagicSparky in forum Video ConversionReplies: 3Last Post: 24th Mar 2008, 21:28 -
ColorSpace for commerical DVD's
By mlong30 in forum EditingReplies: 6Last Post: 29th May 2007, 21:16
