My PC keeps on crashing when I use my DVDrw & CDrw drives. I reformatted in november as I could not burn anything, only rip and read. All seemed well but just recently every time we use the drives up comes the blue screen of deathIt's an evesham PC and my 3 years ran out in december (very handy). Before I go and buy two more drives I wondered if anyone could throw any light on the matter
the pc dosen't seem to like windows media 11 so Ive gone back to 9 but it still crashes. Got shut of some freeware and scanned and had all updates on everything. Would taking out the drives and putting them back help or maybe see if I could update the drives. I suppose I could find time to phone them but I think it depends on who you get on the other end of the phone
Cheers![]()
Results 1 to 9 of 9
don't know exactly as the screen is only on for about 10seconds but I have just noticed the bottomOriginally Posted by deckard8
line is a row of 0's with 8E at the end and then some other numbers in ()'s. Its never up there long enough for me to read
Cheers -
Hardware driver error perhaps? That's what I recall 8E being. Could also be PIO vs DMA mode on the drive channel.
Before you change anything, do a Registry backup of your system with this tiny app - Rdilly.
http://www.joejoesoft.com/cms/file.php?f=rdv110.zip&c=6fafec0 ... d43976c98a
All you have to do is unzip the app, click on rdilly.exe and it will create the backup.
The VB script below will force XP to check for DMA drive channel capability on the next boot. Just run it (download and double click) and restart your system.
http://winhlp.com/tools/resetdma.vbs
Another possible culprit is the ASPI drivers, usually called Winaspi32, or something similar if you're using Nero. We'll look into that after you try the above. -
Almost certainly an issue with the drive hardware and/or its driver(s).
In the kernel world, everything must behave exactly as defined. If any driver does something that the OS deems wrong, the OS issues what is known as a "bug check" - the BSOD.
To get more information, you can configure the OS to keep the BSOD on screen, rather than reboot. See http://support.microsoft.com/kb/307973
The error ending 8E is KERNEL_MODE_EXCEPTION_NOT_HANDLED
More here: http://www.osronline.com/DDKx/ddtools/bccodes_59k7.htm
So, please configure your system to keep the BSOD on screen and write down as much as you can
John Miller -
I had a similar problem that went away after I replaced the power supply. Something to think about if nothing turns up on the software front...
if the fault occurred in November, you still could qualify as a warranty repair. Its only January...
its not likely the drives themselves died simultaneously; but when you reformatted, you set the clock back on all the updates etc too- are you sure you got them all? were there any firmware updates for the drives? your best bet may be to get somebody to redo your redo... or it could be something absurdly embarassingly simple
thanks for all the replies I'll check it all out over the next couple of days and let you know
Thanks for the help -
All seems fine and dandy, for now. Apparently it was my Pinnacle Instanrwrite software. After the first dozen crashes and sent reports Mircrosoft identified it as Pinnacle I/W so I removed it and hey presto I can now rip, burn and play cd's. Not tried dvd's yet. Hopefully all will be well.
Blue Screen of Death (BSOD)
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Dec 2009, 05:31 -
Inspiron B130 ... Blue Screen of Death
By lacywest in forum ComputerReplies: 2Last Post: 30th Nov 2008, 08:30 -
Recovery Files/Blue Screen Of Death!
By Squid_uk in forum ComputerReplies: 37Last Post: 19th Nov 2008, 18:24 -
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 15:35 -
Blue Screen of Death while converting .avi to DVD
By robwbright in forum ComputerReplies: 7Last Post: 5th Oct 2007, 21:53
