Hi
I'm looking for a budget basic dvd recorder that can record tv programs off a sky box and give a decent quality picture on playback.
No other bells and whistles required.
Can anyone recommend one
Thanx
I would suggest a Pioneer DVD Recorder. Even some of their older models are still very good. You may want to check and see if if Sky Box has any copy protection measures that would prevent you from recording.
LiteOn
Pioneer would seem a bit above budget but maybe I will look for a used one
Thanx for replies. -
I would avoid used one.Originally Posted by bill99
Buy a new one according to your budget and get a proper warranty.
DVD recorders without a hard drive are not so expensive any more. -
Didn't Pioneer get out of the recorder market?
You should search the forums for SKY, there are a few people who find it tricky to use a recorder with one. Also there is:
https://www.videohelp.com/dvdrecorders -
Why do people keep repeating this? Pioneer may quit in the future, no new models, but there is stock on shelves and they work fine.Originally Posted by handyguyWant my help? Ask here! (not via PM!)
So what's a basic Tivo (read: DVD recorder with built-in Hard Drive) cost?
By snafubaby in forum DVD & Blu-ray RecordersReplies: 14Last Post: 18th Dec 2011, 12:53 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
most basic way of copy to dvd
By ellabbs in forum Newbie / General discussionsReplies: 7Last Post: 5th Nov 2008, 16:13 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
