I need help choosing a 18x internal DVD burner for my quiet PC.
These are what I want:
- quiet
- reliable (low error rate, less chance of creating a coaster)
- performance (speed)
- compatibility with different media
- region-free or exists a region-free firmware for it
- inexpensive
- preferrably brand name
Any recommendation for a model or brand in general?
Thanks.
LG-H22N
http://www.newegg.com/Product/Product.asp?Item=N82E16827136103
LG-H42N
http://www.newegg.com/Product/Product.asp?Item=N82E16827136108
The LG-H10N drives are quiet and can be crosslfashed to the H12N firmware then it will be able to burn dvd discs at 18x speed.
LITEON has 18x and 20x dvd burners. I have the LITEON 18x dvd burner that sounds like a airplane taking off. I've read on the LITEON forum that some 18x drives are noisy and others aren't. I think it's the luck of the draw but I bought my drive for $30.00 bucks and crossflashed it to the BENQ 1800 drive.
I'd recommend a BENQ 1800 but it's not going to released in the USA. -
So your LITEON 18x dvd burner suddenly became quiet after you flashed it to BENQ 1800Originally Posted by budz
Hell no it still sounds like a airplane is taking off!!!Originally Posted by terence
Nope the drive is still loud even after crossflashing it to the BENQ 1800 firmware. At the moment I have it flashed back to the LITEON firmware using C0deKing's fast patch & it's still loud.
Get the LG if you want a quiet drive.
Need a new reliable DVD-R disk
By cynikalhedonist in forum MediaReplies: 10Last Post: 23rd Feb 2011, 16:28 -
New Asus DRW-1814BLT Sata 18x Burning slowly Nero7
By DAVE440 in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Sep 2007, 02:16 -
Is there a reliable DVD-R DL Disc?
By faramith in forum MediaReplies: 10Last Post: 20th Aug 2007, 13:19 -
Is DVD-RW backup reliable?
By bevills1 in forum ComputerReplies: 15Last Post: 21st Jun 2007, 16:01 -
Ativa 18x dvd writer is real slow and tried everything to speed it up!!
By rotwiler in forum DVD & Blu-ray WritersReplies: 6Last Post: 13th May 2007, 01:21
