Well, I haven't used iDVD in a while and now it doesn't seem to work for me.
OS 10.4.7
iMovie 6.0.3 (267.2)
iDVD 6.0.3 (791)
both are current in sys update. In not using 10.4.8 for no good reason other than everythings working fine until now.
iMovie works ( from my DV camera) makes AIFF, QTmmovies
any ideas from the cognocenti?
cheers
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
ye olde standby...
iDVD not working properly
if not that, then trash the com.apple.iDVD.plist file, and restart.
works everytime...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks terr
Ill get to that a little later today.
iDVD encodes the video ( by their little check box) but then stops working when it gets to the audio encoding
then I have to force quit.
will let you know. takes a long time to make the QT files, am doing that now
cheersMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
nope. still 'jams up' at the audio encoding. it doesn't crash, just stops responding.
then I have to do a force quit.
I had only one permission to repair. I had two lDVD.plist to dump but did not restrart the computer after deleting the two plists
should I try those permisions again and dump the new plist and then restart?
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
to reply to my own thread: I got some intersting answers of all places the actual Apple discussion forum!
look under iDVD 6
iDVD takes 10 minutes to nap a little between video encoding and audio encoding. on the app window nothing happens during that time
I saw some minor ram changes in the activity panel
cheers and thanksMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
force audio sync during conversion
By dtmp in forum Video ConversionReplies: 1Last Post: 5th Aug 2009, 16:52 -
Force Mono Audio in XP?
By nickolasj80 in forum ComputerReplies: 2Last Post: 31st May 2009, 19:39 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 01:05 -
No Audio in iDVD
By The Monkees in forum MacReplies: 8Last Post: 12th Feb 2008, 18:35 -
iDVD 6 - No audio track on burned DVD?
By KWagner in forum MacReplies: 1Last Post: 12th Sep 2007, 10:31
