Hi!
So I have a few AVI files that I thought were in the same format, but when I load them into TFM it tells me that one of them is different and will not allow me to go ahead with the conversion. How can I fix this problem and get all the files into the same standard so they will be accepted. Is there a program I can use for this or what way should I go about trying to figure out why the one file is different from the others? Thanks!![]()
Encode each AVI separately. Bring them together as you author them as DVD. In TDA, you just add them to the same track, then remove the chapter point TDA automatically generates at the join.
/Mats
The correct way to crop and encode anamorphic DVDs?
By harbourshin in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2011, 21:32 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29 -
How do I merge 2 AVI to DVD adding saturation +black levels?
By JoeBolden in forum Video ConversionReplies: 2Last Post: 23rd Jul 2008, 12:01 -
won't encode full file, and will only do certain file formats
By GregDz in forum ffmpegX general discussionReplies: 0Last Post: 21st Jun 2008, 21:27 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09
