Ok my cap card STILL works just fine, hardware wise, because when im on MSN and i send my webcam and I have my cap card connected, it's stil send the image from my PS2 or TV and it works just fine.
But I used to capture from WMM and WinDVR3 perfectly, and now I cannot. WMM completely locks up the computer and WinDVR3 says the specified capture format is not supported by hardware which is bs because t is an it was before for a loooong time. Wassup with that?
Well, something has changed.
Have you added/deleted hardware/software?John Miller -
I doubt it, I mean I do have a WebCam. BUT, when i go to the webcam it appears as disconnected so that lets me know the computer recognises it's off and the cap card is on since I get visual on MSN.
Also I'm sure the WebCam drivers have been in the computer at the same time as the capture ones and it has allowed me to use both at the same time. -
It is possible the web cam installer put a codec of some sort on your system and it is interfering.
Has the problem only occurred since installing the web cam software?John Miller -
I'm gonna remove my web cam drivers and comeback to you.Maybe that'll help.
Still nothing, sigh. This thing has worked forever I don't understand why WinDVR3 doesn't even show any visual any more it's just the window and where the video should be there's just the background of my computer or whatever window i got open. Why does it work on msn... I close MSN and try w WinDVR with everything closed nothing.
Who would have thunk it lol. The cable was not working correctly.
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 14:09 -
Gamebridge--Capture Card Problems
By Magma999 in forum Capturing and VCRReplies: 3Last Post: 25th Apr 2009, 14:23 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14 -
Capturing footage-problems ...
By perik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 7th Dec 2008, 18:11
