I'm trying to attached an old Samsung VP-K60 Camcorder to PC as a webcam.
The cables are round, yellow and white and are described as Audio and Video cables and fit into a Scart connector
Thanks, Stephen
You'll need an analogue capture card/box of some sort.
A dedicated USB webcam may prove cheaper.John Miller -
Thanks John, but I want to stream the capture and the camcorder will definately give a better image than a webcam. What sort of capture box did you have in mind? I might be able to obtain a used one on Ebay for exampleOriginally Posted by JohnnyMalaria
Thanks, Stephen -
Here's a bunch:
http://www.usbgear.com/USB-Video-Capture.html
(But, before you plump for one, make sure it supports PAL!)John Miller -
One of these will do the job nicely http://svp.co.uk/products-solo.php?pid=1196
although from what I've read about the video quality on older Samsung camcorders, the video quality from a webcam would be just as good.....
Camcorder, webcam or something else?
By Haopengyou in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 18th Mar 2012, 06:18 -
I need a camcorder to stream HD like a webcam. What can I get ?
By jfmonod in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 21st Oct 2011, 09:33 -
easycap to use as webcam with camcorder
By natwarchauhan in forum Newbie / General discussionsReplies: 0Last Post: 28th Mar 2011, 20:35 -
Camcorder JVC used as webcam
By wrummmmm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jul 2009, 07:56 -
Using Digital Camcorder JVC as WEBCAM for my PC
By manhnt in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2007, 20:03
