Hello , I use Nero 6 to burn mp3 cd's.Nero came with the DVD-RW I purchased , well , I have always used them to burn the cd's but as of yesterday I cant burn anything , I get a 'Communication Failure'.
Ive tried a firmware upgrade for the DVDRW but have already got the latest version plus I uninstalled it through Device Manager and restarted the computer , tried another burn but the same error showed up once again.
Anyone know what to do or what to try ?
thanks
geo
geo g,
Probably the first step would be to take a look at this section at the Nero web site. It gives Nero's take on the error message you're getting. Since they wrote the program, they would have the best understanding of the circumstances that would cause that error message to be displayed.
If that doesn't help, posting a burn log should help us to see what's wrong.
Welcome to VideoHelp. -
I have encountered and solved this problem at least in my specific situation. I could read and rip fine but burning would fail almost immediately with communicatiosn failure.
Turns out in a google search I came upon another forum and the problem was the IDE CABLE. the newer drives require 80 pin cables The system had 40 pin cables. I replaced the cable and its working fine now.
the difference is the 40 pin cables the connectors are all black. The 80 pin has blue grey and black connectors.
Once I did that my problem went away.
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 16:25 -
Burn Failure (Nero 7)
By TunkaFrankie in forum DVD & Blu-ray WritersReplies: 26Last Post: 11th Sep 2008, 22:35 -
Internal Target Failure on Nero
By ChonasMan in forum Authoring (VCD/SVCD)Replies: 12Last Post: 10th Aug 2008, 19:45 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 14:28 -
Burning Failure
By Em in forum Newbie / General discussionsReplies: 6Last Post: 25th Jun 2007, 03:21
