I know this is probably simple, but I just can not find it. I normally use the Wizard. At the very end when I am about to process the file(s) it has a box that has the Save output file as. It is saving it as elementary streams. I go to uncheck the box so it will save as an mpg, but it is grayed out.
How can I set this as save as MPG?
Hi Baldrick,
So if I understand you, there is no "switch" to save as mux vs. elementary streams. It is a matter of what type of audio you have as an input? -
If you use mpeg audio you can switch between mux and elemantary streams but not if you use wav audio. I think you set the audio in the first step in the wizard...
I knew it had to be simple. You were exactly right!
Thank you.
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 16:42 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 13:07 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 09:52 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
