    Jun 2006
    Hi all,
    I'm trying to test h.264 for mobile video.
    According to the h.264 levels (http://en.wikipedia.org/wiki/H.264) (scrol downl to Levels table), video for mobile devices needs to be encoded at 64Kbps or 128Kbps or 192Kbps with a resolution of 176x144 (known as QCIF) at 15 frames per second.
    Having downloaded Sharktooth's profiles and selecting the CE-Baseline as I should have, I notice the following:
    a) bitrate on Video Configuraiton is set to 1000 (luckily I think I can set from the Bitrate Calculator Window)
    b) framerate is set to 25fps (as my source files) and cannot set it to 15fps required by the level
    c) I can only encode having the AVC level set to 'Unrestricted' whereas I should be able to set to level 1
    Is there anyone who can help me tackle the above in order to achieve hardware compatibility?
    Thanks in advance.
    sp.
  2. The profile you're using "CE" is for consumer electronic devices.
    I don't believe Megui provides mobile profiles.
    You'll will have to change the Bitrate/levels by pressing the "load default" button in the encoder config and/or create/update a profile for the mobile spec. As for the frame rate and resizing, you must do this in your avisynth script.
    Maybe try Super as an alternative.
    Jun 2006
    Thanks for your speedy reply,
    I didn't realise CE stands for Consumer Electronics. I'll try both options you suggested.
