hi!
okay so here is my situation. I used avi2iso to convert 6 tv shows to DVD in the VIDEO_TS folder and the beginning of each episode is a chapter. Now I want to know step by step what is the best/easiest way to add a realtively simple chapter menu to the dvd where i can select which episde to go to from the already authored DVD i have currently? thanks!!![]()
Download and install the 30 day demo of Tmpgenc DVD Author, and use the Add Video option to import your episodes, create a menu and export a new DVD structure. If the file you have is an ISO you will have to mount it with Daemontools or similar first for TDA to read it.
Read my blog here.
Titlewriter may be able to do this -- though I haven't used that function myself.
It comes with a bunch of help files and templates for menus. -
You could also try downloading the Trial of DVD LabPro, and use the Attach External VTS to add in each of the movies. Create a VMGM Menu with buttons to link to each of the attached VTS's (either movie or "menu").
Or if you like using PGCedit, use DLP to create simple MENU DVD, and then PGCedit can load in that menu -- you can then re-assign the buttons to your movies.
Regards,
George
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 10:07 -
Simple DVD Menu
By Burner2009 in forum Authoring (DVD)Replies: 5Last Post: 21st Nov 2008, 14:47 -
adding subtitles to an authored DVD
By exekutive in forum ffmpegX general discussionReplies: 1Last Post: 29th Dec 2007, 12:20 -
how to recompile customs menu to authored dvd?
By nick101181 in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2007, 18:11
