I've built a DVD with slides made into menus with video in DVD Studio Pro 3. I burn the discs thru Toast 7. They play fine on a stand alone DVD player and pretty much OK thru DVD playhback software on a PC. But they do not play well in Windows Media Player. How can I burn DVD's so they will be compatible to play on laptops, desktops and especially WM player? Any help would be greatly appreciated, as the client insists on using this playback method. Thanks in advance.
Mike
If burned DVD plays fine on standalone DVD player and in Apple DVD player application then all is fine with burned DVD and its fully compatibile with any proper player /standalone, laptops or desktop machines/...However, WIndows Media Player is known to make problems where there is none and therefore either tell your client not to play through wmp cause its a pure garbage of the app or to try to install some older version of it /prior to 11 which is the biggest garbage/.
If client continue to insist to play the DVD through wmp, tell him to contact Micro$oft and make complains to them.. -
Thanks for your help. You verified what I was thinking. Is that the proper way to burn or should I just build, format and burn everything thru DVD Studio Pro?
Mike -
Either method is sound, but the way you are doing,
about 50 to 60% of video professionals do it the
way you described in your original post.
it's what I teach....FWTW....;-P"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
16:9 divx movie won't play properly on my TV
By romino in forum Video ConversionReplies: 4Last Post: 22nd Oct 2010, 06:36 -
MPG won't play properly in VideoRedo
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2010, 17:13 -
HDTV2DVD outputs won't play back properly
By papatop in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 10th Dec 2008, 19:45 -
Files that won't play properly in WMP or after conversion
By Trapper Dave in forum Video ConversionReplies: 1Last Post: 3rd Jun 2007, 13:26
