How can I tell if an avi or mpg video file is CC without playing it?
Tks,
paul
Results 1 to 10 of 10
I m ignoranrt. I have a deaf friend and some of the bit torrents that I have downloaded for her (mpg, avi) and burned to DVD have been CC and others have not. All were prograns that were orignally CC. I searched on torrent sites and found nothing about CC. I asked at a torrent forum and it was suggested that I look in the nfo file. I have never seen info on CC in an nfo file.
AVIs can contain closed captions.
Without playing an AVI to find out, you'll probably need to dump the RIFF structure. Basically, this will identify what kinds are tracks are present - usually video and audio, sometimes text.
e.g: http://www.thugsatbay.com/tab/?q=other_tabriffdump (I haven't tested it).John Miller -
does not work for me. Any other ideas?Originally Posted by JohnnyMalaria
I'm Deaf, if I need subtitles I just use one of the subtitle sites, they are free. Subscene.com Opersubtitles.org
I never saw an avi with CCs & I have watched thousands of Avi's. I don't know how they would do it, as CCs are entered on line 21. -
Perhaps he means "hearing impaired text" that you see in some subtitles:Originally Posted by handyguy
~ Music
[man laughs]
etc. -
For use on a computer, CCs can (and have been) encoded into AVI.Originally Posted by handyguy
Some sofware/hardware combinations will convert the AVI-embedded information into line 21 data.
DV can embedded CC and Teletext within the digital data stream. My DSR-11 can detect line 21 data, encode it into the DV stream and record to tape. You can edit the text information (via FireWire and a computer) and, with the same deck, send it back to any TV that has a line 21 decoder.John Miller -
That's nice. However, that doesn't account for why I never see one. Might not be very practical when you can just use subtitles?
But the person wanted to know how they could find our if an avi has CCs or not. -
As I suggested, without playing it, you need to dump the RIFF structure and see if there is a text stream.
This won't work with some, though. There are some products that support direct coding of Line 21. i.e., the video frames contain the (usually) hidden lines. See http://www.cpcweb.com/ for examples.John Miller
Question how to extract Closed Captions (cc) from VCR tape
By jimdagys in forum SubtitleReplies: 8Last Post: 24th Jul 2009, 16:48 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 03:54 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 13th Feb 2008, 00:14 -
question about rippping closed caption from DVD with VSRip
By jimdagys in forum SubtitleReplies: 1Last Post: 17th Oct 2007, 12:54 -
question about how to display closed captions in KM player
By jimdagys in forum SubtitleReplies: 2Last Post: 17th Oct 2007, 07:08
