I'm sorry if this question has already been answered in the 'how to' section. I tried to find the answer but did not. I bought a SONY Vaio computer in the US and am now back in the UK trying to play UK DVDs on it and it does not work. Is there some way to reset the region? When I bought the computer I did not think the region bs was still happening but obviously U was wrong and should have looked into it before making assumptions. Thank you to anyone who can help me. - Novice
Nope, the region bs is alive and kicking.
Typically, find your DVD player in Device Manager. Right-click to open the Properties and there should be a tab labelled DVD Region. You can change it there. But, as per DVD specification, you only get 5 goes (including one already used up).
If you have a need to play Region 1 still, best bet is to get a second, external DVD player to plug in and keep it as Region 1.John Miller -
Try a region free software like ANyDVD or DVD-REgion free.
https://www.videohelp.com/play#dvdregionfree
And PLEASE use a better subject. We don't want to guess what it is about. I changed it this time. You can also change it by clicking on the edit-button on your first post. -
I am not sure about laptop drives in Sony Computer but their retail IDE drives are rebadged Liteon-s. If you google liteon and region free you'll find a plenty of advice.
All DVD drives can be reset for different region 5 times. Look in your laptop manual, it should tell you how to do it.
Hard reset for BDP3000
By alexh110 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Oct 2011, 10:37 -
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 18:45 -
How to reset the DVD drive region code?
By coody in forum DVD & Blu-ray WritersReplies: 13Last Post: 17th Apr 2010, 04:42 -
How do I reset the code?
By deltarory in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2010, 05:35 -
Magnavox mdv430 How to reset
By soluble in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:27
