Hello all. I think this is the correct place for this post. Sorry if it isn't.
I just hooked up my S-video cord to my vid. card and my TV. I went into properties and under settings I have set up the 2nd display as my TV. Easy so far. But when I do this, I only see my desktop wallpaper, and nothing else displays when I run it on my CPU. How do I get everything that I play on my desktop to show on my TV? I know this is probably a very general question, so if anyone could point me in the right direction that would be very greatly appretiated. Thank you!!
Sounds like you have extended the desktop to the second display.
If you want the second display to be exactly the same as the main one, turn off the extended desktop. You may need to select a "clone" mode.
It might also help to know what graphics card you have.John Miller -
Yes, I have 'Extend my windows desktop onto this monitor' checked. Should i not? How do i enable clone mode.
BTW- I have a 128 mb ATI Radeon x600 SE -
It depends on your hardware. For my nVidia card, I use the nVidia software to select clone mode. On laptops, it's simple (a keyboard function does it).
Have a look in the ATI documentation or software configuration. Often ATI adds a load of tabs to the Display Properties that you can get to by right-clicking on the Desktop on choosing Properties...John Miller
New to this video world....need setup help
By Ssvar in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 15:42 -
Newbie looking for help with video equipment setup
By hoosier812 in forum Newbie / General discussionsReplies: 5Last Post: 14th Sep 2010, 23:05 -
Newbie Advice for Cheap Multimedia Studio Setup
By dartmanx in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 14:16 -
Which Hard Drives/setup are best for capturing video/video editing?
By Balefor in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2008, 14:24 -
video to setup tv colors
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 06:57
