Hello all!
Forgive me if this a simple question please, but I am new to the world of video editing.
Now, I just downloaded this really funny clip from the web and it was too dark.
Being a bit resourceful I typed in how to brighten a video clip in google and up popped videohelp.com.. a brilliant site.
SO I registered and found a chaps posting requesting something similar!
Following your folks advice I opened windows movie maker on my XP and found how to brighten the clip..brilliant.
Now however, after saving the file it will no longer play in windows media player because the format is .MSWMM -ie a windows movie maker project..
Please advise how I can save it as original ie wmv, or just convert it to wmv in windows movie maker..
Many thanks for your help anyone
Kind regards
Steve Knott
Google is your Friend
To save your project so you can finish working on it at a later time then use "File - Save Project As". Then when you want to finish it you simply use "File - Open" then browse to and open your saved project files.
When your project is done and you want the finished .wmv file then you would use "File - Save Movie File" or better yet - click "View - Task Plane" (which enables the basic 1-2-3 functions all in handy order on the screen - then click on #3-Finish Movie - Save to my Computer. Choose from the encoding specs you like.
Although easy to use and figure out WMM is still a junk program IMO. I don't use it.
Good luck. -
Dear KrispyOriginally Posted by Krispy Kritter
Many thanks for replying to my newbie post so soon. I tried what you suggested and it has worked perfectly. marvellous!!!
Kind regards
Steve Knott wildlife photographer ( stills only ) -
Very nice portfolioOriginally Posted by Steve Knott
I'm impressed -
Thanks Scorpion King,
had a huge one nip me whilst on safari recently, thought I was going to die untila witch doc told me it was only the tiny blak ones that killed you!!
got me out of mischief re editing wmv files,
cheers Steve -
Thanks kindly Baldrick for getting me out of mischief!
All good now, cheers
Steve Knott
Best luma brightening filter for VirtualDub?
By callmebc in forum EditingReplies: 19Last Post: 27th Jan 2013, 15:25 -
Brightening a DVD
By RAN1DOM2 in forum EditingReplies: 3Last Post: 9th Aug 2009, 16:20 -
brightening dark MPEG-2 skin tones without brightening anything else
By rch15 in forum EditingReplies: 4Last Post: 18th Aug 2008, 02:53 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24 -
brightening color
By Russo in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2007, 15:44
