I can't upgrade driver ATI and MMC 7.0 in my computer. Installation works, but
The image is larger than window of MMC,
time shifting locks everything and in capturing files are corrupted.. It's a mistery.
Someone told me that i have to modify registry, but i don't know how.
This is configuration:
mainboard Gygabyte 7DXCC
AMD Athlon 1200
VIA CHipset 686
RAM DDR Samsung 128Mb
BIOS Award 6.00 PG
HARD DISK Maxtor 30 Gb 7200
Windows ME
Soundblaster Live 5.1
After I have unistalled Driver ATI 3063 and MMc 7.00, reinstall via 4 in 1 driver, then Direct X 8 and video update, I delete all ATI Keys in registry, I Install new driver( I have tried 7075 or 7189) then MMC 7.1.
Nothing, I have to uninstall everything and setup 3063 and MMC7.0
Please help me
pm6p
i had the same problem , when i change my capture card
( from tv wonder to a.i.w. radeon )you have to delete
every driver and mmc and go back to windows display driver
, then install the mmc 7.1
i didn't figure it alone , ati support me in a direct
phone conversation during the sequence ( have to pay
the long distance ! )phone # 905-882-2626 -
or you can just follow the directions for registry deletes found here under ati aiw capture, and it's free.
when i try to use time shifting a message says: error in quartz.dll and in MFC42dll .
in panel control it's not possible to set" Ati all in wonder capture" as default.
I have to install MMC7.0 and the old driver again.
Help me, thanks -
also install the ATI dvd 4.1 update. it fixes a lot of capture related lockups, even if you never use the dvd player.
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 15:52 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 16:25 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
