Hi
I'm using Virtual Dub Mod to edit a subtitle in the video (an .ass file). In order to do that, I have to save it in "Full Compression Mode" and I use the XviD Codec with the following settings: Simple Advanced @ L5 . Single . Quality: 3 (So output is around 160 MB)
However,
when it's done encoding the video has a lot of lag. It sometimes stops as if not all the frames are there (although they are because the lag occurs randomly). I tested it on several computers, so it's really a problem with the video (as the "raw" input video doesn't have this).
I tried to do this (the encoding) with other files too and absolutely no problems occured.
Could there be something wrong with the input video
but more importantly:
How do I fix it so that the video will be playing normally ?
Tnx in advance.
The video => moving slowly then jump to correct frame then moving slowely again
I've also tried other codecs, but they seem to give me the same problem
(In Direct Stream Copy and Fast Recompress (with same XviD settings) the video will result fine, but then there are no subtitles there...)
Leaving the subtitle out or use another sort of subtitle file doesn't resolve the problem.
Closed Thread
AnonymousGuest
Don't double (or even less triple) post please!
Continue here:
https://forum.videohelp.com/viewtopic.php?p=1645768#1645768
/Mats
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 22:09 -
EasyCAP w/ Ulead and Pinnacle - Video Stuttering/Jumping/Lagging problem
By Logan289 in forum Capturing and VCRReplies: 0Last Post: 30th May 2010, 14:25 -
VLC media player lagging video
By Obamargarine in forum Software PlayingReplies: 4Last Post: 19th May 2009, 21:36 -
Adobe Premiere 2.0 Video Lagging! But Why?
By daiweb in forum Video Streaming DownloadingReplies: 2Last Post: 19th May 2009, 09:13 -
ffd causing video lagging
By billsimard in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:19
