I'm using RivaEncoder to convert FLV to avi.
All OK.
The problem is that I want to play the video on my pocket PC.
I've got program on their to play Divx video.
The video itself plays on my pocket PC: but no sound.
It plays OK on my PC.
Not a problem still.
I thought I could get Virtualdubmod to save as Divx avi.
But... my version doesn't read the video.
Am I missing something like an extra codec?
Thanks.
OM
Results 1 to 10 of 10
Riva FLV Encoder convert FLV to AVI using FFmpeg & Lame.
After conversion AVI file contain video track with FourCC FMP4 (FFmpeg/ffdshow ISO MPEG-4) & audio track (MPEG (MP1/MP2)).
Video track no problem (ffdshow VfW), but audio...
Better method is demux FLV to AVI & MP3 in FLV Extract.
After - join & convert in VirtualDubMod (with turn on FLV1 and/or VP6F/FLV4 in ffdshow VfW).
Or... use FLV Splitter & ffdshow - create AviSynth script (DirectShowSource) & use VirtualDubMod.
Or... just use SUPER, MediaCoder, WinFF, Dr.DivX...
(Default in FLV audio is MPEG-1 Layer 3)
(Sorry for language.) -
I'm not sure I follow.Originally Posted by OM2
Isn't Riva FLV Encoder exactly that....it encodes TO FLV? -
Old guide - https://forum.videohelp.com/viewtopic.php?t=259578Originally Posted by hech54
It's worked, but it's poor method. -
i tried doing the above.Originally Posted by Placio74
i installed the latest version of ffdshow (as instructed for flv extract).
(previously... i couldn't play the avi file... now i can after installing the latest ffdshow.)
unfortunately... my virtualdubmode still can't process the video file.
i would assume i would have the same problem trying some of the other methods suggested.
what am i missing for virtualdubmod?
thanks. -
kewl.
thanks for the reply.
why would this have been turned off by default? -
also... i see H.263 (+) is disabled.
si there a good reason for this?
should i have this turned on?
thanks. -
Not necessarily.Originally Posted by OM2
It's useful when You find AVI with H.263 (rarely, but possible) and edit or convert him in VirtualDub.
Like other codecs in ffdshow VfW.
well having either the flv or the h.263 turned on: does this do any harm?
maybe like take more processing power or something?
i tried winff: wasn't really happy with the results.
the resultant avi file was less quality than the flv, but just about watchable.
thanks to all the replies though: i'm now using flv extract and joing with virtualdubmod.
results: wow!
thanks for all the help.
problems converting MOV -> FLV
By dannyboy2090 in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2010, 13:50 -
Problems converting FLV
By am_dew in forum Video ConversionReplies: 8Last Post: 15th Jul 2010, 00:02 -
Having problems converting flv to MP4
By Norkusa in forum ffmpegX general discussionReplies: 5Last Post: 16th Aug 2009, 21:54 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 23:09 -
problems converting to flv
By devriesfilms in forum MacReplies: 7Last Post: 2nd Apr 2008, 13:36
