i have a few mpegs that won'y open in QT or mpegstreamclip or ffmpeg, when i use VLC to play the info tells me it has the MP43 codec...
Results 1 to 11 of 11
no luck, i wonder if there is a pc app that i can run in VPC that would allow me to switch these files to a different codec...
ok,i got it to work....all i did was rename the files with .avi instead of .mpg
hmm, thanks so much for this as I had the exact same issue. How did you figure out to change the file extension?Originally Posted by pixel zombie
MP43 cannot be embedded in an .mpg file. It's a Video For Windows codec thant can only be used in .avi or .asf container. Your file had an incorrect file extension. VLC doesn't rely on the file extension to guess the type of file. Quicktime throws an error because he detects .avi informations in what seemed to be an .mpg file, so Quicktime just thinks the file is corrupted.Originally Posted by markwmJean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
FFdshow DivX 3 MP43 + Purple Marks
By Baharroth in forum Capturing and VCRReplies: 1Last Post: 26th May 2009, 08:31 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
