My friend tells me that I can just burn my movies as a data cd or data dvd and this dvd player will play them. They are in avi format and I could get a couple on each cd. I was just wondering because it doesn't mention avi in the description but my friend says that avi is included under the mpeg-4 heading. Is he right, because I don't want to shell out unnecesarily. The link is below
http://www.liteonit.com/global/index.php?option=com_content&task=view&id=28&Itemid=63
If you mean the LVW-5001, I don't see anywhere that it can play any form of AVI or MPEG-4.
I'm not sure it can play MPEGs by itself or just formatted VCDs, SVCDs, DVDs, JPEGs and MP3 and CD audio discs.
But others may be more familiar with that model.
And welcome to our forums.
Search for a dvd player that will play divx (a simplification) that should sort out your problems
You (to shop assistant) " I would like a DVD player that plays divx?"
Shop assistant "Certainly sir take a look at all these models over here".... points to large section of players.
You (delighted!) "Wow I'll take that shiny slim plastic one please"
Many liteon models play divx.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
burning divx files as data to play on dvd player
By penguyen in forum Authoring (DVD)Replies: 4Last Post: 30th Jul 2011, 11:54 -
Play non-finalized data dvd?
By julius_zombie in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2010, 06:46 -
Which specifications should I be looking for to play my data discs?
By K_Kat in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th Jun 2009, 11:53 -
will a avi data disc play in a divx player?
By nobbyiscool in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2007, 15:23
