Hey guys. I've got a little dilemma here.
I'm using PowerDVD 6.5 to play back my HD-DVDs, but I want to use the CoreAVC decoder to handle other h./x264 file that I create/download because the processor usage and image quality is much, MUCH better.
The problem is that the Cyberlink decoder takes over from the CoreAVC decoder for ALL DirectShow 264 playback (Zoom Player), and I can't figure out a way around this.
Any suggestions?
I was able to lower the merit of the Cyberlink h.264 AVC filter to "do not use" and raised the merit of the CoreAVC filter to "Normal +1" using the Radlight Filter Manager version 1.4.
This seems to have worked, as I can still play HD-DVDs with PowerDVD 6.5 while my other 264 files will play in Media Player Classic using the CoreAVC decoder.
However, now Zoom Player seems to be broken. It won't play ANY media file and just hangs when I try to load one. I'll have to troubleshoot this s bit more.
But the important thing is that it works. Thanks for the tip!
Update: Reinstalling the latest Zoom Player fixed it. Now everything works perfectly!
MPC-HC and CoreAVC 3.0, please help.
By Crucio in forum Software PlayingReplies: 13Last Post: 15th Sep 2012, 17:30 -
MPC+CoreAVC
By quzma in forum Software PlayingReplies: 0Last Post: 1st Jan 2012, 17:51 -
Ripbot with Coreavc
By sanosuke in forum Video ConversionReplies: 4Last Post: 11th May 2010, 08:45 -
cyberlink TV Enhance h.264 hardware acceleration
By jamespoo in forum Software PlayingReplies: 1Last Post: 1st May 2010, 20:24 -
Is there an alternative to CoreAVC? - Please....
By CineManno in forum Video ConversionReplies: 5Last Post: 31st Dec 2007, 22:16
