I used to burn dvd-r dl with nero and they played perfectly on my philips dvp 642 dvd player.
So I've decided to buy another Philips dvp 642 dvd player and on this one the burned dvd did not play anymore.
I have checked the two dvd players, they are virtually the sames and have both the same version of the firmware installed but on the first one, the burned double layers dvd played perfectly but on the other one, they used to freeze after 30 minutes.
I have borrowed a third philips dvp 642 (same firmware as the others) and on this one, the burned dvd also freeze.
I tried another brand of blank dvd (the first I used were philips, I changed for verbatim) : same result.
I tried another burning software (I usually copy my dvd with dvd shrink and burned them with nero, so i tried anydvd and clonedvd 2) with no more success...
If any of you could explain me why my burned dvd play wonderfully with one of my philips dvp 642 dvd player but not with an other I will be eternelly gratefull
J.C
Possibly just luck. The 642 officially only supports DVD+R (not -R or DL)
Google is your Friend
letterbox problem on burned dvd ...
By perik in forum MacReplies: 5Last Post: 8th Jun 2010, 02:01 -
Problem With Stand alone DVD player and Burned Dvds
By tealmarlin in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2009, 14:02 -
Menu problem DVD-- burned in MythDora4 (dvdauthor)
By media601 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 22:12 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 07:46 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
