I am unfortunately a noob, so please be kind.![]()
I would like to take a short 10 or 20 second clip from a protected DVD and turn it into a animated GIF to use on the web, like an avatar or something.
Any suggestions would be appreciated. I would prefer one complete software package to do this but I guess there may not be something like this available. So if I need a bunch of software I will do what it takes. I need decent quality also.
Results 1 to 30 of 34
10 to 20 seconds of video in "good quality" will lead to a large GIF file.
Does it have to be GIF?
There are better options - e.g., Flash movies.John Miller -
I guess it does not have to be a gif, but I thought most avatars were animated gifs. Are you saying that even a small sized animated gif like 120 X 120 would still be of large size?Originally Posted by JohnnyMalaria
If so, then I guess flash would be ok. Would flash be the best quality to hard disk size? -
Ulead Cool 3D can make animated gifs from AVI files. It's a slightly comlicated process and took me a while to work out how to do it. There is a free trial.
Here's one I made earlier . . .
588kb.
112 x 84 pixels
Frame Count - 73
I made up the sequence using video editing softare, then imported it into Cool 3D.
If you need any tips on how to use cool 3D, let me know. -
That looks great! I will try the Ulead software.Originally Posted by 12Quidkidinnit
Now, what did you use to get the clip from the dvd to the avi file? Did you convert the entire dvd to avi or did you select the few seconds from the dvd and only convert the few seconds to avi.? -
If you are trying to create an avatar that long, you'll probably annoy a lot of people - 0.5MB is rather much! It took a while on my ISDN connection.
John Miller -
What software is recommended to convert a small 10 or 20 second avi file to a animated gif or a flash file? Someone suggested Ulead Cool 3D, any others?
Any input would be appreciated. -
Here's a free solution.
Install WinFF
download my profiles:
http://www.geocities.com/virtualdoobmon/presets.exe.zip
Save this file as "presets.exe" (loosing the .zip)
save it to your desktop and launch.
This will install a new "presets.xlm" file to the WinFF directory and override the orginal. All the original profiles are still there all that i added is a "Vid2gif"
Launch Winff from desktop and load files to encode.
Select VID2GIF and start conversion.
You can override the default frame size (120x120) and rate (3fps) by entering the values in the specified input boxes.
Hope this helps -
It wasn't off a DVD. It's some AVI footage I shot a few days ago. I used premiere pro 1.5 to make up that short clip, then deinterlaced it, because it was terrible at first. Even now, those railings outside that office still look like they're shimmering a bit.Originally Posted by 4thDoctorWhoFan
I'm no ffmpeg command line person by any means but:
You might want to try FFMPEG in command line mode. I used this command line to make an animated gif file and it works. Just select the following ffmpeg line and paste it into a dos window in the same folder as ffmpeg is in (the installation folder for winff) and hit enter. You must also have your video file in that folder or supply the path to it in the filename entry.
-i means the input video name follows
video.avi is the name of my original video file
-pix_fmt rgb24 means to convert to rgb24 (had to do this to get it to create gif files)
-r 10.0 means framerate 10.0fps
-loop_output 0 means to loop the gif file endlessly
-f gif means to create animated gif file
video.gif means my output file name
The easiest method I know to use command line tools in Windows is to enable "Open Command Windows Here" on the right-click menu in Windows Explorer. I use XP PowerToys - TweakXP to enable that. I open Windows Explorer to my needed folder then right click it's name and open the command window. I then open Notepad to edit my command lines then select-copy and paste them into the command window. Very simple to do.
You can also do the same by opening the command window then CD to your working folder. A little harder but still very doable.
Good luck. -
You import video directly into Ulead gif animator. Make sure you only use a short clip... :P
Depends on how many frames you use and the size of the color pallete.Originally Posted by 4thDoctorWhoFan -
Look at 12Quidkidinnit's example. 112 x 84 pixels, 73 frames = over 0.5MB.Originally Posted by 4thDoctorWhoFan
For avatar use, that's excessive!
For different purposes, it may not be (you have to think about the target audience).John Miller -
I agree.
My example video was 80x80, 4seconds, 10fps. The output filesize was around 159KB. I had the framerate down lower which helped a little but still far from the 10KB limit for avatars at this site. 40 frames I guess.
Coalman's waving flag GIF shows 8 frames and 11.6KB. @ 40 frames the filesize would be around 58KB.
Converting real video to animated gif is possible but the filesize is going to be larger. -
The color pallete is a big factor in the size as are other things... Here's the car file at 200k, 1/3 the original. Just like compressing an MPEG you lose quality.
Thanks to everyone that contributed. I really appreciate it.
I used FairUse Wizard to extract a short clip from a dvd and convert it to an avi file.
Now I am currently using Ulead Gif Animator in an attempt to make a gif. This software is average at best. It lacks a lot of features. For instance: I cannot find a way to select all the frames at once in order to change the delay rate. There is no "select all". But it does seem to be doing the trick however I will be on the hunt for some better software.
I am going to try and use SUPER next just to see the difference between the software.
Unfortunately, it seems that Ulead Cool 3D does not allow for animated gif's in it's trial version. I did want to try this software, but the animated gif selection is "greyed" out in the trial version. -
What else would you suggest?Originally Posted by JohnnyMalaria
Basically, I just want to put a small (10 or 20 second) avi clip on the web for people to see. It might be on a website or even as a signature on a forum. Is avi to flash a better way? -
My attempt at the car gif.
I used MGI PhotoSuite 4, opened the car gif file and deleted over 2/3 of the frames then changed the frame duration from 0.10 to 0.30 (in the program). The new filesize is 122K or a reduction of 462K from the original 584K.
It's a little jumpy :P , but it's smaller....
Even at this smaller filesize it's still far too big for avatar use. -
Such as? As far as creating a GIF animation there isn't much you can't do with it.... GIF animators of that caliber are few and far between, they just don't have them.... Bear in mind that software is quite old, gif animations are pretty much dead because of flash.Originally Posted by 4thDoctorWhoFan
Highlight the first frame by selecting it, highlight the last frame by pressing shifting and selecting it. All the frames should now be highlighted.... right click and select the frame delay.For instance: I cannot find a way to select all the frames at once in order to change the delay rate. There is no "select all".
Cool 3-D Production is far beyond any gif animator and would be complete overkill for what you want to do. It's for making video animations to use as overlays and works in a 3-D environment allowing for lighting etc... Something similar and free comparitivley would be Wax, there was another one mentioned that looked quite good that was free as well but I can't remember the name of it. -
70k ... l can go as low as you want, gets pretty ratty after this though.
pretty cool coalman
I have learned one thing with all this.... if you ever want to load an animated gif into VirtualDubMod for editing it's simple. Import the gif file into Ulead VideoStudio v10 and save it out as an AVI. Works good.
What to do with it next I don't know.
275K. Resized to 80x60.
I give up.
Ok, then perhaps I am barking up the wrong tree. Animated GIF is out and Flash is in apparently.Originally Posted by thecoalman
Can avatars be a Flash file?
Can flash files be uploaded as image files?
I have noticed that Flash banner ads play automatically. I have to do nothing except to have the flash plug-in installed in my browser. Will the same be true if I upload a flash file as a image file that I create?
Should I start a new thread since this is a little off topic from the original post? -
Last night, while enduring the State of the Vegetable, I played around with Flash and other options.
The smallest Flash movie I could create from the original animated GIF was about 0.5MB. Basically, it just embedded the GIF.
So I used Animation Shop to export the GIF as separate frames, import those into Flash and create a movie, hoping Flash would compress the images. No.
I then tried creating a variety of AVI files. The best I could get was this:
test.avi
(14.5kB, 73 frames, 112 x 84).
So, for Flash 6 (the highest I can create), the files are large.
Also, not all browsers will play Flash movies by default.
e.g., on our site, there is a Flash movie the simulates the appearance of one of our products. Some browsers only show the fall-back still image:
http://www.enosoft.net/enhanceddvdecoder.html
So, you also need to add the HTML code to detect whether Flash is supported or not....
Can you explain a bit more about exactly what you want to do? I think we have all assumed you want an avatar. But...John Miller -
Here's my attempt:
Step1: Open AnimGif in QTPro, Export to UncompressedAVI
Step2: Open AVI in Vdub, smart smooth (default settings), smart resize to 86x64 (precise bilinear), Save again as Uncompressed AVI
Step3: Open AVI in Adobe Imageready, select all animation frames, Save Optimized as Animated GIF (adjusting palette, color bitdepth, diffusion or no dithering, etc)
Here's my result:
It's 93kB, 86x64 @~32Colors 10fps
with a little bit more cropping, a little bit more dithering adjustment and smart color bitdepth reduction, and a little less framerate (7.5?) could cut it down further to probably ~1/2 that.
But the big thing with GIFs (and any palettized color model) is the PALETTE! Use of a combined-image SuperPalette that can be further optimized using something like DeBabbellizer (if it's still available) could probably cut it down to a 1/3 (~32kB).
Other than that, you'd have to do fancy tricks with transparency and background replacement, or just make it shorter in length.
Scott -
Not unless it's supported and it's not on this forum, not aware of any others that do either but it's defintely possible.Originally Posted by 4thDoctorWhoFan
Depends on what you are making, for video where each frame wouldhave to be recreated it's not much better than gif except you can use more than 256 colors. For most standard flash banner ads you'll notice instead of animated figures you have moving objects. Those only require a single source, the animation is created by moving the source from point A to point B and other affects such as fading can be created.Originally Posted by JohnnyMalaria -
Agreed. I was refering to the particular GIF we have all been playing withOriginally Posted by thecoalman
The Flash movie on our site is very simple and only 26kB ( http://www.enosoft.net/decodermovie.swf )John Miller
Animated Gif Maker
By budwzr in forum EditingReplies: 12Last Post: 10th Jan 2012, 12:09 -
YouTube clip -> animated gif
By raz1337 in forum Video ConversionReplies: 2Last Post: 8th Oct 2010, 23:14 -
Insert animated gif in movie clip - avi, swf or else
By wilderwildness in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 09:45 -
animated gif
By snafubaby in forum Newbie / General discussionsReplies: 14Last Post: 27th Jan 2008, 14:41 -
how do i slow down an animated gif?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Nov 2007, 02:12
